cfdgeekAnswer
Hi
We have a tutorial case of natural convection. https://support.ptc.com/help/creo/creo_pma/r9.0/italian/index.html#page/tutorials_pma/NaturalConvection.html
For import/export BCs, what do you want to import/export? Thanks.
cfdgeek13-AquamarineAnswer
Hi
SZdore13-AquamarineAuthor
Thank you very much for the information you provided. What I need is the natural heat dissipation when pcb works!  Thank you again!
Hi yes, that tutorial cases explains what needs to do for a heat transfer case with natural convection. The briefly summary is here,
1. add heat module
2. change fluid density as ideal gas law
3. turn on gravity and set gravity direction
4. use mesh location to both(internal+external)
5. specify pressure intial value and also BC values due to gravity change p = rho * g * height
6. run a steady state or transient run
Please contact your support engineer if you need further assistant.
