Impact analysis in Creo vs. explicit analysis
Does anyone have any experience from doing impact analysis in Creo (i.e. modal/dynamic) vs. explicit analysis (i.e. LS Dyna etc) ?
Is there any point in trying to get some useful results, or should I just forget about it?
In this case it is a type of valve that closes "with a bang" as air pressure on one side of the valve disappears... Since there is contact involved, I guess it's no point trying in Creo.
/Mats L/
Hello Mats,
I am attaching a link on the hammer if it can help.
Yes, shame simulate does not do.
Kind regards.
Denis.
http://www.maplesoft.com/applications/view.aspx?SID=129503
Merci Denis,
In this case it is the mass of the valve plug itself that causes the impact, not the media, which is air.
/M
2-Explorer
October 19, 2014
It really depends on whether the highly transient nature of the event results in any significant non-linear effects (for example, materials that are highly strain-rate dependent). Even then, I don't know how much weight I'd place behind the results; if your going at this from a trend point of view, then maybe.
