Inch Units to Millimeters 50 parts one click?
Hi Group,
Is there a way to Globally set the Model Properties from Inch units to
Millimeters?
I have an assembly with say 50 parts, units are in inch.
I want to globally change the units of all parts with one magical wave
of my Creo wand.
Without opening each part and subassembly, how would I do this and can
it be done?
JSCOTT
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
If you have Creo Simulate: Retrieve the assembly in Simulate and change units for all components. Then back in Creo an save.
/Bjarne
