Interface error - why?
I try to push down the top part (see pict.). The inside of ring part should contact with outside faces of lower part but the result doesnt show this:
Before they go into contact the distance between faces of interfaces starts to increase.
Why?
Roland
It needs large displacements turned on to resolve the sliding.
I replicated the design and the results shown when large displacement is OFF.
