Interpenetration of solid
Hello!
I would like to prevent the interprenetation of solids, that are "linked" by fasteners...
You have any idea?
Thank you
Good Life
Federico
So, I'm forced to make a non-linear analisys?
It is not possibile to avoid it?
The other option would be to use a bonded interface - that would prevent interpenetration, but would also prevent separation.
In some other analysis package there's a sort of 'tied' interface, which keeps parts in contant but allows them to slide, but I'm not aware of anything equivalent in Mechanica.
By definition, if you want surfaces to be able to separate but not penetrate, that's a non-linearity...
