Interpreting my results
- 8 replies
- 5085 views
- Translate All
Hi guys,
I need a little help. I have run a simple simulation of a bolt under different loads. The UTS of the steel of the bolt is 530 MPa and each bolt is loaded with 265 MN. My results show three windows, one which is Stress Von mises, the second displacement and the third stress max prin.
Am I correct in thinking that the first is showing the areas of stress? Im confused since this appears to be up to 182 GPa.
The second is showing how far the bolt would be deformed and stretched and the third how the stress is mapped,how does this differ from the first one. I have been unable to find this information on the PTC site. Any help would be much appreciated.
