Is it possible to precisely specify Query points, using coordinates, or planes?
It will be nice of using excel table, and create specific XYZ points.
I need to check the FEA stress, against strain gages.
Boris
    dandersonAnswer
    Boris,
    When you ran the analysis, The analysis should have created a folder with the name of the analysis.
    In this folder there should be a file called (Your_Analysis_Name.rpt). Open this file with a text editor.
    In this file you will find the data your are looking for at the end of the file.
    Hope this helps,
    Don Anderson
    Should look something like this:
    Load Set: LoadSet1: PRT0001
    Resultant Load on Model:
    in global X direction: -3.731300e-10
    in global Y direction: 7.743008e-11
    in global Z direction: -2.000000e+03
    Measures:
    max_beam_bending: 0.000000e+00
    max_beam_tensile: 0.000000e+00
    max_beam_torsion: 0.000000e+00
    max_beam_total: 0.000000e+00
    max_disp_mag: 2.273793e-01
    max_disp_x: 1.274006e-02
    max_disp_y: -1.749406e-02
    max_disp_z: -2.264426e-01
    max_prin_mag*: -2.202082e+02
    max_rot_mag: 0.000000e+00
    max_rot_x: 0.000000e+00
    max_rot_y: 0.000000e+00
    max_rot_z: 0.000000e+00
    max_stress_prin: 2.323141e+01
    max_stress_vm*: 1.225728e+02
    max_stress_xx*: -9.745248e+01
    max_stress_xy*: 7.909744e+00
    max_stress_xz*: 7.430658e+00
    max_stress_yy*: -9.913390e+01
    max_stress_yz*: 1.070902e+01
    max_stress_zz*: -2.191157e+02
    min_stress_prin*: -2.202082e+02
    strain_energy: 1.765350e+02
    Measure1*: 1.225728e+02
    Measure2: 2.662682e+00
    Measure3: 7.468690e+00
    Measure4_PNT10: 7.497607e+00
    Measure4_PNT11: 7.910385e+00
    Measure4_PNT12*: 6.300263e+00
    Measure4_PNT13*: 5.404658e+00
    Measure4_PNT4: 5.468962e+00
    Measure4_PNT5: 7.303314e+00
    Measure4_PNT6: 8.184689e+00
    Measure4_PNT7: 8.172292e+00
    Measure4_PNT8: 4.504136e+00
    Measure4_PNT9: 6.807737e+00
    ** Warning: The measures marked by an asterisk (*) were evaluated
    at (or close to) results singularities. The values of these
    measures may be inaccurate, and you must use engineering judgment
    when interpreting them.
    Analysis "Analysis222" Completed (11:02:18)
    Memory and Disk Usage:
    Machine Type: Windows XP 64 Bit Edition
    RAM Allocation for Solver (megabytes): 6288.0
    Total Elapsed Time (seconds): 1.34
    Total CPU Time (seconds): 0.61
    Maximum Memory Usage (kilobytes): 8233989
    Working Directory Disk Usage (kilobytes): 4096
    Results Directory Size (kilobytes):
    815 .\Analysis222
    Maximum Data Base Working File Sizes (kilobytes):
    4096 .\..\..\..\..\temp\Analysis222.tmp\kel1.bas
    Run Completed
    Tue Mar 13, 2012 11:02:18
    Boris,
    You might try using a Simulation Measure over Selected Geometry at Point. (see image below)
    If you create your points as a pattern it will create measures for each of the points you have
    defined in the pattern. (make sure to select the pattern)
    You could then map the measure results in the .rpt file in the analysis directory to an excel file sheet.
    Hope this helps,
    Don Anderson
    Don,
    Thanks a lot.
    It is very helpful.
    I created the pattern of the points, using CREO.
    After that, I opened a Simulation, and created the measures from the points.
    When simulation is finished, I cannot found .rpt file in the directory, and cannot see any measures results.
    Probably, I missed something. Please, guide me step by step.
    By the way, you already seriously helped me.
    Boris
    danderson1-VisitorAnswer
    Boris,
    Hope this helps,
    Don Anderson
    Measures:
    815 .\Analysis222
    Run Completed
