Is the function string_ends() gone from relations?
I've noticed that when I examine the relations in my start part I made few months ago, there is inserted into the text a red arrow with a cryptic error:
->Invalid data type combination at left side of expression
I couldn't really understand it and so I tried to restart from scratch.  But now when I write this sample relation into an empty part:
if string_ends(MY_FILENAME_STRING,"prt")
   MY_FILENAME_TYPE = "PART"
endif
and try to save, the system says "Relations have errors"
and there is a less cryptic error flagged with a red arrow inserted into the text like this:
-> Invalid symbol 'string_ends' found
endif
My first guess is that the function has been removed from Creo 2.0 (M160)?  This is because it doesn't show up in the available functions list.  But this post shows that function used to be in this list in 2014...
Is string_length() still a valid relation function?
But I'm also thinking that's so unlike PTC as they keep everything for the sake of backward compatiblity...
So is there something I'm missing here?
menderAnswer
This function was erroneously restricted (made hidden and/or made dependent on a license check) in Creo 2 M140 and Creo 3 M020.  As you noted, it is important to preserve access to relation functions indefinitely to support backwards compatibility.  The functionality is restored (made visible and/or not dependent on checks) in Creo 2 M160 and Creo 3 M050.  Apologies for any trouble this has caused you.
mender12-AmethystAnswer
Paul Sobejko‌, do you know when these functions were added?  I've never even heard of them before today.  I dug around in the Creo online help and couldn't find them anywhere.  The only place I could find them documented at all was in the PTC knowledge base (maintenance required).   Article CS160989.
(I wonder if there's an undocumented Real-to-String function hiding out there somewhere.  Wouldn't that be nice!)
Another vote for a Real-to-String function!!
Im sure it would take a programmer at PTC 15 minutes to create this function (that the user community has been asking for the last 20 years)
What a monkey to do..
