ISDX image W5 Creo
Creo Users,
We have multiple foundation licenses and a few ISDX. We have parts that used ISDX to place an image in a part. When opened at work w/ foundation license the image shows up fine, but if open offsite it is a grey box, no image. I am guessing it is a path issue. Can someone point me in the right direction on this? Path on network issue or license issue?
Thank you
Ryan Crisp | Senior Mechanical Engineer
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
www.prioritydesigns.com<">http://www.prioritydesigns.com>
CONFIDENTIALITY NOTICE: This email along with any attachments contains proprietary information, some of which may be legally privileged. If you are not an intended recipient of this email, you must not disclose, copy or take any action in reliance of this transmission. If you received this email in error, please contact the sender and permanently delete all copies of the email and any attachments.
Ryan,
It's not a license issue - it's the path. The trace sketch image must reside in the same directory as the part in order for Creo to open it properly. If it's not in that same directory it shows up as grayed out. Unfortunately, it doesn't store the image file as an integral piece of the part file - just looks at it as a linked item. Not sure if that will change in Creo 1.0
Mike Brattoli
Moen Incorporated
Global Brand Development
Engineering Systems Administrator
25300 Al Moen Drive
North Olmsted, OH 44070
Ryan,
Thanks to Paul Sagar at PTC here's an answer to your situation. A config option exists that will store the trace sketch as well as any other textures with your part, allowing it to open regardless of whether or not you are on your network:
save_texture_with_model yes
Mike Brattoli
Moen Incorporated
25300 Al Moen Drive
