Leader Note showing differently on two CREO Parametric instances
Hi All,
We added some leader notes in a drawing that we were working on. When we open the drawing in the CREO Parametric instance we worked on, they are oriented to the right.
If we open it on another users CREO Parametric instance, they are oriented to the left.
If there a CREO Parametric Setting that affects this or can cause this behaviour?
Alex1988Answer
Issue was cause by a missing part in the assembly. Correcting this led to the leader notes being shown correctly.
@Alex1988 wrote:
Hi All,
please publish pictures showing the problem. If you can create test data (part+drawing), pack the into zip file and upload this zip file.
Alex198813-AquamarineAuthor
Hi Martin,
Sorry for the delay in my response.
Please find the example attached. Picture 1 shows what we need it to be on all CREO Parametric instances.  Picture 2 shows how it is on a small number of CREO Parametric instances.
Alex
@Alex1988 wrote:
Hi Martin,
Alex
it seems to me that the 1st Creo uses a different font to display the note than the 2nd Creo. The size of space characters is different. Please check annotation text properties on both computers.
Alex198813-AquamarineAuthorAnswer
