May 31, 2017 5:40 PM UTC
License request failed for feature
I have problem with Creo 3.0. When I run Creo, it shows a warning message wich says:
Invalid feature name: [FEATURE NAME]
Next I click "OK" and the application shuts down.
I found similar topics on this support, but the advice in this topic doesn't work:
(Creo 3 - Invalid feature name)
Do you have some tips for my problem?
Mahesh_Sharma
22-Sapphire I
May 31, 2017 6:02 PM UTC
Raffael,
Are you using Commercial or student edition of Creo?
May 31, 2017 6:19 PM UTC
@mahesh sharma
I'm using the student version, but i got it fixed already.
Before i was using the new Creo 3.0 M130 version (the newest i had atleast) which gave me that error, but now i tried installing it with an older installation version and it worked!
But thanks anyways!
Mahesh_Sharma
22-Sapphire I
May 31, 2017 6:40 PM UTC
Raffael,
Good to know that Creo is working now. You may mark your reply as correct answer for the post.
Jun 1, 2017 6:11 AM UTC
I guess that the root of the problem is missing parametric.psf file in Creo installation.
<Creo3_LOADPOINT>\Creo 3.0\Mxxx\Parametric\bin\parametric.psf
MH
