3-Newcomer
Live simulation with Nvidea RTX A400
I want to use Creo for simulations, but I can't access the simulation interface.
The button under Application > Simulate is grayed out. The Flow and Mold Analysis buttons are both in color, even though I don’t have a license for Flow Analysis and can’t access the Flow environment.
Is this due to the graphics card’s RAM, which is sufficient but not recommended or because the A400 isn't supported?
Thank in advance
The Hardware Check reports:
Your hardware is not qualified for Creo Simulation Live
Your graphic card (GPU) is a supported NVIDIA CUDA based card. However GPU does not have enough video RAM to optimally support Creo Simulation Live.
Creo Simulation Live relies on the latest graphics processing unit technology to provide its computation and visual experience and requires the following:
A dedicated NVIDIA graphics processing unit card (Quadro recommended) based on the Kepler, Maxwell, or Pascal architecture. Most dedicated NVIDIA Graphics Processing Unit cards produced in 2013 or later, are based on one of these architectures.
At least 4GB of video RAM (8GB preferred) on the Graphics Processing Unit
 - Machine Name :
 - CUDA version supported by driver : 13.2
 - Details about NVIDIA cards found :
      - NVIDIA RTX A400
 - Dedicated Video Memory : 4094  MB
 - Details about RTX cards found :
      - Driver Status : Supported
      - Device Status : VALID_RTX_DEVICE
VladimirNAnswer
Take a look:
VladimirN24-Ruby IVAnswer
Take a look:
