Loader/Truck tying down analysis in simulate
Hi peoples ,
Iam sure most of you would have performed analysis on (ISO-15818) lifting and tying down using analysis tools.
I would like to know how did you set up your model for tying down analysis in creo simulate.
In real time for tying your truck/loader to trailer technicians will be using chain or rope, how are you replicating the same in your FEA thru spring or beam. Please specify the properties of spring and beam which ever you are using.
Do you run two load case for longitudinal & transverse or any other simplest way.
Appreciate your time and thanks in advance.
Shankar
