Material issue even after proper material selection- In Creo Ansys Simulation
I was trying my first Simulation in Creo Ansys Simulation, facing an issue during creation of mesh. I checked with multiple YouTube video but still I could get the solution.
"Material Some bodies or simulation objects in your model
do not have a valid material type/elasticity model assigned."
Please help me to resolve.
I am using Creo 10.0.7.0
KenFarley
The message is telling you exactly what is wrong. Unlike a lot of error messages.
To run an analysis you have to explicitly assign a material to every model in the assembly you are analyzing. You have to go through the components of the assembly and check whether each and every one has a material assigned. This does not mean "do you have a material assigned to a part" but "have you assigned a material to each part within analysis program".
I've run Creo simulations but not the Ansys type, so if I'm wrong about this anyone can feel free to correct me.
sjbiswas4-ParticipantAuthor
Hello KenFarley,
Thank you for your replying 😊!
I have checked the material assignment to the component. Actually, I was facing this issue with an Assembly with multiple plastic components then I tried with single component but still facing the same, issue.
I am not sure what to do but I am little sure this issue with material property.
Suraj
my suggestion >>> please contact PTC Support.
Catalina
Community Manager
Hi @sjbiswas ,
If so, please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina | PTC Community Manager
Hello Catalina,
Sorry to say that still I didn't get any solution for my issue.
Could you please let me know how to connect with Creo support team.
Thank you,
Suraj
StephenW
