Measure in creo view
Hi All, Is there a way to measure the coordinates between one asm to another in creo view?
unfortunately your question is completely incomprehensible.
Dear Martin,
I would like to provide a detailed explanation. I have accessed a large assembly in Creo View and am currently searching for a specific sub-assembly. Once I identify the X, Y, and Z coordinates, I need to replicate these coordinates in the Creo software, using a base part from the large assembly as a reference. Therefore, to accurately replicate the location, I require the coordinates of the sub-assembly as referenced from the large assembly within Creo View.
Praveen.
@PE_10657737 wrote:
Dear Martin,
Praveen.
I don't understand why you want to use Creo View when you will then be working in Creo Parametric. Simply use Creo Parametric.
Catalina
Community Manager
Hi @PE_10657737,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster, as well as articles on our Knowledge Base.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
