Mechanism Clearance Check with Spatial Field Point Reporting.pptx
The enhancement request / Product Idea would allow you to run a full motion analysis and report in the parts where on the part(s) the clearance is less than the amount specified in the analysis by highlighting the surfaces in yellow.  This would allow you to open the parts and see what material needs to be removed from the parts. As you can see the yellow highlighted surfaces need to be cut back to maintain an minimum 65mm clearance from the tire to the body panels.
See Product Idea     Mechanism Clearance Check with Spatial Field Point Reporting (highlight on parts where clearance needs to be added)
