mechanisms, trace curves and designing the largest parts...
Guru's,
I have an assembly with a mechanism. It contains a link, pinned on both ends, with one pin a rotating arm and the other into a piston in a cylinder with a slider joint. I am trying to maximize the thickness of the link with respect to it's long axis. The limitation is the clearance to the cylinder walls. What I have done is put points on the cylinder and then used the trace curve function to produce trace curves on the link. Then I used those curves as references for the profile of the link all the way around. It looks like this with the link round in cross section with varying diameters as shown:
The issue is that since the link is NOT free to rotate, it COULD be thicker in the direction perpendicular to the ones shown above. Essentially, it could have an oval or elliptical cross section of varying size. The point/trace curve method described above would work, and since there is symmetry I only have to do this for 180º around the link axis as opposed to 360º, but it seems tedious. SOOOOOOO... I am wondering if there is a better way? Maybe something I am missing? Any suggestions???
thanks in advance....
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
A motion envelope would cover the 3D problem compared to the trace curves 2D nature.
If you have access to Behavioral Modeling Extension you could try optimizing it that way using e.g. a minimum clearance value measured between the arm and cylinder. But you will need some good driving dimensions.
Bjarne Frandsen
Paul,
As others have suggested. Try using a motion envelope using the casing as the 'pen' part and the yoke as the 'paper' part. Assemble the resulting faceted part with the yoke and you should be able to modify the yoke part so that the size is maximised. If the part see significant compressive load then I would suggest carrying out a buckling analysis as well as a static analysis. Making the shape oval will not change the buckling mode, so it would probably be simpler to keep a circular cross section.
Rod
Rod Giles
Polaris Industries
That would give me the shape of the motion of the moving link and a
fixed cylinder. Essentially I need the shape of the cylinder with
respect to a fixed link so I can maximize the link.
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Guru's
This suggestion below seems to indicate that you can set "pen" and "paper" parts for motion envelopes. As far as I can see, there are no options for this. Does anyone know HOW you can do this? What are the picks?
Essentially, if I redefined my mechanism such that the link was the ground/stationary part and the cylinder is the moving part a motion envelope WOULD give me what I need. I'll have to think about how difficult that would be, but it could be pretty slick...
The other good suggestion was to use BMX to run an optimization. Essentially, I could set up the link as a multi-section sweep and run the optimization to tweak the individual section dimensions to a given clearance...
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
