Mesh does not plot in ansys simulation
When using ANSYS Simulation, I am able to solve the model fine.  The results show a green check mark.  When I plot a result, the color legend shows up.  However, the contours do not plot on the part being simulated.  In addition, when I click on "display mesh", the part changes from a shaded solid body to a wireframe.  The elements do not plot.
Can you help me figure out how to get the e
You can do it only with advanced results
