Model Check date format issue
I am using Creo Parametric Release 4.0 and DatecodeM140
Here are the errors that I faced
It is required to modify date format of Model Check option in Creo 4.0. User is unable to modify date format from ex. Tue Mar 20 2022 to ex. 20-03-2022. Please suggest options to update/modify date format of Model Check in Creo Parametric 4.0.
More details.
I do see that date format in the header of the report, but that is all. Is this the date format you would like changed? That format is probably hard coded and I, for one, like to see it in that format.
Date: Mon Sep 12 2022 08:57:25
Hi BenLoosli,
Thanks for your reply.
We already mapped model check date property from Creo to Teamcenter. But in Teamcenter we need the date format to be like this (ex. 12-09-2022). The thing is we are trying to update/modify Model Check date format in Creo. My question is - Is it possible to modify Model Check date format in Creo? If it is not possible, Is there any other way to address this issue?
Without some customized code, I don't think that is possible.
On method would be to use relations to change the formatting, but even that gets messy and you would then need to take your custom date format to TC instead of the Model Check date.
