ModelCheck not matching Assembly Parts
I am running model check on a top level assembly. When I look at the assembly report there are parts that have errors however when i go into those parts or open them separately to run model check there are no errors.
StephenW
If you click the part in the hyperlink as shown in your image, it should show you what the error is on the part.
That's my issue. They do not match. When I click on the part it says no errors despite saying there are errors in the assembly view.
Mahesh_Sharma
22-Sapphire I
​Hi @ZC_10909252,
Can you share a sample data and ModelCHECK configuration to review?
Thanks.
Community Moderator
Hi ​@ZC_10909252,
checking in on your recent post.
Please respond so the community can help you further with your issue.
If your issue is now solved, please tell us how you solved it and “Mark as An Accepted Solution” to help others with the same issue.
Anurag
