Modelcheck parameters
HI, I would like add some check with modelcheck.
Can youtell me if is possible and the way to do that for:
  • Check if a view is out of the format (in drawing)
  • Check failed attached dimensions (in drawing)
  • Make a warning if the intersection volume is up han a value (in assembly)
  • Make warning on some parameters conditions and error on over parameters conditions (in part and assembly)
  • Add length restriction on a parameter - number caracters < 30 on description parameter (in part and assembly)
Thanks for your help and sorry for my bad english !
Ben
