Sep 25, 2017 9:15 PM UTC
Press-fit contact analysis with no load--unable to run
- 7 replies
- 7984 views
- Translate All
I have a simple contact analysis that I would like to run. I have a gear that is press-fit onto a shaft. Instead of enforcing a displacement (the distance the gear in pressed onto the shaft), I wanted to start with the gear already in it's final location and simply run the analysis with the press-fit box checked and the maximum interpenetration set to my press-fit distance (0.038mm in this case). However Simulate gives me an error that I can't define the analysis without either a load set or enforced displacement. Is there a setting I have incorrect? I thought I could run a press-fit without needing a load set or enforced displacement. I've attached my assembly with the setup I'm having issues with.
