Press Fit of Housing (Aluminium) and Laminated Stack (electric steel) with Temperature load
I have problem when I make Press fit simulation in Creo Simulate 4.0.
I have a housing (material aluminium AW6063-T66) and inside part laminated stack (M250-35A). There is interference fit between housing and laminated stack. I want to Analise the contact between Housing and Laminated Stack which is needed also by higher operating temperature. So I add  a temperature Load of 100°C and 20°C as reference temperature.
When I check the displacments after the simulation is completed there are the same displacements in time 0 and time 1. Meanwhile there is a difference in Stresses Von Mises in time 0 and time1. It would be logical that in time 0 there would Creo showed the displacments that are a cosequence of interferance fit between housing and laminated stackat room temperature.
And than in time 1 there would be additional displacments due to Temperature load (delta T=80°C and becouse of different expansion temperature coeficients of Aluminium and Steel)
Can anyone give me an explanations or advice  how to get the right displacements also in time 1?
