[procad] WF4 M170 / Win7x64 Dell T3500 Quadro 2000 Drivers
Hey gang
Anybody have the secret squirrel settings for a Nvidia Quadro 2000
running on a Dell T3500?
Win7x64 WF4 M170
These issues exist on two new identical Dell pc's
* Dragging the "Insert Here" bar up and down in the model tree
leaves behind ghost images of the bar
* Resizing the model tree window left to right, right to left and
the graphics window jerks around
* Having a couple model windows open (2-3), sometimes the model
is not displayed on the screen until you rotate it.
PTC certified driver for Nvidia Quadro 2000 is listed as 8.17.12.5929
Installed and tested with no luck so far
Nvidia control panel does not list Pro/Engineer as a default base
profile so customization will be required
If anyone is using this video card and has settings they could share,
that would be great
Jeff L.
Jeff Lippeth <">mailto:-> | Mold Design Engineer
| NyproMold <">http://www.nypromold.com/Nypromold.html> |
Direct:+1.847.855.2226
This e-mail may contain information which is confidential or privileged.
The information is intended to be for the use of the individual or
entity named above. If you are not the intended recipient, be aware
that any disclosure, copying, distribution or use of the contents of
this e-mail is prohibited.
In the event of any error in transmission, unauthorized recipients are
requested to contact the sender immediately and not to disclose or make
use of this information. No employee or agent is authorized to conclude
any binding agreement on behalf of NyproMold with another party by email
without express written confirmation by NyproMold Offices
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
I've had to set Nvidia 3D settings to "3D OpenGL Stereo" to get correct performance in ProE.
Not sure why there is no ProE setting anymore.
If anyone knows a better setting, please share.
David Haigh
I don't see that setting in the Nvidia control panel, where do you set
it?
Doug Schaefer
