proe crashes without any warning while using
This is a big problem for me .If any expert can help me. Please find the solution of my problem by telling me the whole procedure of it. I am using
PROE WILDFIRE 4 since two months . But when i starts working on it . It crashes after 2 minutes and it happens every time. If somehow proe works
for more than 4 minutes then the system gives the blue screen error other wise the system closes the software without any warning. I think that this software is not compatible with my system or it can be something else. I have installed a graphic card and i have increased 1 GB RAM recently . Before it was 1 GB RAM. But i dont think so that there is a problem with the graphic card and the ram . Because before when i was not using the graphic card , proe 4 was giving the same problem and after i installed the graphic card the problem of crashes was the same again. Can i find out permanent solution of my problem. Is there any need of changing the proe confg setting with my system setting ? Please find the solution
My system's configuration:-
OS NameMicrosoft Windows XP Professional
Version5.1.2600 Service Pack 2 Build 2600
OS ManufacturerMicrosoft Corporation
System ModelD865GLC_
System TypeX86-based PC
Processorx86 Family 15 Model 4 Stepping 7 GenuineIntel ~2659 Mhz
Windows DirectoryC:\WINDOWS
System DirectoryC:\WINDOWS\system32
Boot Device\Device\HarddiskVolume1
RAM -2GB
GRAPHIC CARD NVIDIA GEFORCE 6400
if you happen to be running a microsoft intellipoint mouse driver remove it an run a generic mouse driver. that is all I can think of right now.
-Tim
i am using simple mouse of logitech. i am not understanding what are you saying . clear it?
See "Certified and Supported Graphics Cards" in "Hardware Notes - Pro/ENGINEER Wildfire 4.0" (Last updated: June 9, 2010):
http://www.ptc.com/WCMS/files/52592/en/proewf4.pdf
Workstation Hardware Partner listed:
- Dell (http://www.ptc.com/WCMS/files/60077/en/dell_wf4.pdf)
- Fujitsu-Siemens (http://www.ptc.com/WCMS/files/64255/en/fujitsu_siemens_wf4.pdf)
- HP (http://www.ptc.com/WCMS/files/58520/en/hp_wf4.pdf)
- IBM (http://www.ptc.com/WCMS/files/79007/en/ibm_wf4.pdf)
- Lenovo (http://www.ptc.com/WCMS/files/60073/en/lenovo_wf4.pdf)
- Sun (http://www.ptc.com/WCMS/files/62759/en/sun_wf4.pdf)
Sorry!
The Graphics Card NVIDIA GEFORCE 6400 is there no listed.
