Proe favorites links location?
  • October 7, 2010
  • 5 replies
  • 1383 views
Proe Users,
Where does Proe store shortcut favorites links?
Ryan Crisp | Senior Mechanical Engineer
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
<">http://www.prioritydesigns.com> www.prioritydesigns.com
CONFIDENTIALITY NOTICE: This email along with any attachments contains
proprietary information, some of which may be legally privileged. If you are
not an intended recipient of this email, you must not disclose, copy or take
any action in reliance of this transmission. If you received this email in
error, please contact the sender and permanently delete all copies of the
email and any attachments.
This is wherewe store our favorites. Not sure if it is the same for all installs.
C:\work4\ptccache\.Settings\web_favorites.xml
Brian
I'm curious how you get Pro/E to store it in someplace besides buried in
the Windows user directories?
Doug Schaefer
Doug,
Set the variable PTC_WF_ROOT or PTC_WF_HOME.
Regards
Iain
Instead of having favorites stored off in these crazy places that you can't readily find...
You can add a list of favorites to any of your config.pro files. I use this so that many of our corporate mapkeys function on all users PC's. The option is browser_favorite C:\whatever\path\you\want\as\a\favorite
Dave McClinton
MCAD System Administrator
McKesson Automation
724 741 7760
david.mcclinton@mckesson.com
Yes, but starting with WF1 (I think) that config option simply adds them
to the XML file stored deep in the bowels of Windows. Once there, I
believe they are independent of the config option. You cannot change
them or remove them via the 'browser_favorite' config option, you can
only add new.
I used to distribute favorites to our users the same way, but quit when
PTC changed how they were stored.
Doug Schaefer
