ProUITree Popup Menu
I am having trouble getting a pop-up menu (RMB) working for a ProUITree.
Any advice would be appreciated.
In the routine to create the dialog:
ProUIDialogCreate()
ProNotificationSet (PRO_POPUPMENU_CREATE_POST, (ProFunction)
exportDialogPopupCreate);
ProUIDialogActivate (DIALOG_NAME, &status);
ProUIDialogDestroy (DIALOG_NAME);
ProNotificationUnset (PRO_POPUPMENU_CREATE_POST);
The function exportDialogPopupCreate() never gets called despite the dialog
with the tree showing is displayed.
Is there any special way or locatioon to right-click? Any enabling function
that needs to be invoked?
Bob
Bob Monat
Jerand Technical Services, Inc.
bob@jerand.com
www.jerand.com
1-317-875-6087
Hi Bob,
I create RMB Menus in the .res files. I don't know if it is possible this way for your problem.
Declare the RMB:
(MenuPane CLV_OpenMenu
(Components
(PushButton CLV_Open)
(PushButton CLV_Insert)
(PushButton CLV_Mapkey)
(PushButton CLV_OpenPathInExplorer)
(Resources
(CLV_Open.Label "Open")
(CLV_Open.Bitmap "clv_open.gif")
(CLV_Insert.Label "Insert")
(CLV_Mapkey.Label "Mapkey")
(CLV_OpenPathInExplorer.Label "Open Path in Explorer")
(.AttachLeft True)
(.AttachRight True)
(.AttachTop True)
(.AttachBottom True)
! (.VisbileInMenubar 0)
And bind it inside the Resources declaration:
(CLV_List.PopupMenu "CLV_OpenMenu")
After that you can change all the insides like you want. I want to change the options are shown inside the RMBM for the different elements you can choose inside a list (so should be the same inside a tree). So I redeclare the .visible options (ProUIPushbuttonShow / ProUIPushbuttonHide) inside the RMB menu. So the menu is everytime the same, only the shown options change. For the changes I use the select action from the list item (should be also possible on a tree).
Best regards,
Eike
