6-Contributor
Query about thermal simulations
Does anyone know what's the difference between ambient temperature and Farfield temperature?
VladimirNAnswer
"Ambient temperature and farfield temperature are terms commonly used in the context of heat transfer and thermal analysis. Here's the difference between the two:
1. Ambient temperature: This refers to the temperature of the immediate surroundings or environment in which an object or system is located. It represents the temperature of the air or fluid in direct contact with the object. The ambient temperature can vary depending on factors such as location, time of day, season, and any heating or cooling sources nearby.
In thermal analysis, the ambient temperature is often used as a boundary condition to model the heat transfer between an object and its environment. It is typically assumed to be constant unless specified otherwise.
2. Farfield temperature: This refers to the temperature of the fluid or medium at a significant distance away from the object or system under consideration. The farfield temperature is used to represent the average temperature of the fluid or medium in the region far away from the object, where the heat transfer effects of the object are negligible.
Farfield temperature is commonly used in computational fluid dynamics (CFD) simulations or for convective heat transfer analysis. It helps determine the heat transfer rate between an object and the surrounding fluid based on the temperature difference between the object and the farfield temperature.
To summarize, ambient temperature represents the temperature of the immediate surroundings, while farfield temperature represents the average temperature of the fluid or medium at a significant distance away from the object".
VladimirN24-Ruby IVAnswer
