reference temp not taking as per specified value with loaded fnf file
I am using Creo Simulate Release 11 and Datecode11.0.1.0
We have created fnf file in creo simulate using FEA mode, then we loaded the fnf in creo simulate UI using external file with temp on required node. During loading we set reference temp as 22, after seeing in previews it shows 0 as ref temp.
We ran multiple thermostructure analysis, but it shows its not taking 22 as ref temp. & showing worst result
Also not loading controlled mesh in Creo simulate
Creo version: 11.0.1.0
    For example, if 1 to 100 nodes are created for a particular model, apply the required load on the specific nodes where you want the load, and apply the reference value on the remaining nodes.
    skunks
    Please ask PTC Support 🤔
    RushikeshJ12-AmethystAuthorAnswer
