Repeat Region Column Model/Rep
So I am familiar with how a this functionality works to get the same item (part number) listed in several dash numbers that are either reps or separate assemblies with the same item/find number.
My question is, is there a way to get this function to work when the same part number is assembled into multiple subassemblies? For instance, I have several parts used several times in two subassemblies of the main assembly. In the repeat region, they are listed as separate find numbers (5,6,7,9 and 12,13,14,15) and I want them to be the same find number.
