Rigid Element Forces
Is there a way to pull the forces in rigid elements in creo simulate?
I use rigid elements to create a stiff connection between points in my simulate models, at some point however I will need to design parts that provide that connection. Is there a way to see the forces carried by the rigid elements to properly size the connection I design?
