Simplified Reps, Footers, Analysis Features
Okay folks, this is a little convoluted, so bear with me.
I have a complex assembly whose purpose is to compare two designs. As such, I have set up a system of simplified reps to show these assemblies in different states of operation. I also have a number of analysis features in place to compare measurements from one design to the other. These features have been placed in the footer of my assembly to guarantee that they'll always be up-to-date whenever I go to get that measurement data from one of them.
The problem is that two of these measurement features fail whenever their rep is not active, and since both reps can't be active at the same time, I always have the "FAILED FEATURE" warning and reminder from ModelCheck when I go to save. Is there a way I can disable this analysis calculation outside of its specified simplified rep? The model tree shows these as features, but I can't turn them on or off in the simplified rep dialog.
Any help? I'm on WF5, M030.
Tim Giauque
Project Engineer II
FN Manufacturing, LLC
Phone (803) 736-0522 x383
Fax (803) 865-3543
