2-Explorer
March 31, 2014
Simulate - Engine is unable to open file
I've seen topics on the knowledge base for this, but they don't help. I'm hoping someone on here can.
I've been running static model FEAs using the same process for years and now I'm getting this: “The engine is unable to open the file .\XXX.rpt. Please check the directory/file permissions.”
I've created new folders for the analyses. I've created new parts from scratch. I've tried to run studies that I've already run in the past successfully. And they are ALL failing. I've even uninstalled CREO 2.0 and reinstalled it. This worked once, then it started failing again.
None of my files or folders have spaces in the names and they don't start with "0". I havefull read/write access to these folders.
