Simulate Lite
I have posted this question to the Analysis forum as well. It may not be the proper place for it because thy most likely use Simulate, not Simulate Lite.
Has anyone heard of any bugs in Simulate Lite that would give wildly incorrect results? I have part that I have specified Polycarbonate (PC-10) as its material and when I run an analysis I get some crazy high stresses like 4.2 x 10 to the 8th PSI at the base of a beam. The kicker is I have actual parts in my hand that I can flex and function fine. The numbers don't make sense to me out of Simulate Lite. I have looked at my material properties a few time in an attempt to eliminate an error. I am on Creo2 M080.
Dean,
Are you able to see the mesh?
After running the analysis, the evaluation dialog box (AutoGem tool and others), gives you blue circles in all the cases confirming that the analysis was OK?
