2-Explorer
October 17, 2013
Simulation Icons
Is there a way to change how big the simulation icons (load, constraints, etc) appear on the screen? Mine are really small on my laptop, making it hard to see them.
Assuming you are refering to the simulation icons on the model then yes you can provided you use the older 2D icons. In the simulation display menu under "settings" tab, select the checkbox for "icons" and increase the scale. With the 3D icons you can uncheck the "zoom-invariant" box and that will make the icons larger as you zoom into the model.
Hope that helps,
- J -
2-Explorer
October 21, 2013
Unfortunatley, I'm trying to scale up the 3D icons.
Shuan,
Un-check Zoom-Invariant and see if this helps.simulate+3d+icon+size+settings.jpg
Don Anderson
