Feb 13, 2012 4:57 PM UTC
Sorting parts list table by function
Is there a way to sort a table by a function based on a part name?
I have a parts lists which is generated using repeat region tables. I need to sort the entries so that those which are designed items and having a name length of 13 characters appear first and then the purchased parts (e.g. screws, handles etc) which have a 7 digit name length appear afterwards. Any file which doesn't have a 7 or 13 character file name is a dummy part/asm and would be manually filtered out, unless I can find a way of automating that as well.
&asm.mbr.name
42345-0001-00
42345-0002-00
42355-0001-00
22-3456
23-2345
34-9865
Designed parts always start with a 4 and stock parts start with a 2 or 3 so the default sort option of "&asm.mbr.name forward" lists parts in the wrong order.
Feb 15, 2012 11:04 AM UTC
Hi
I have done this WF5
but have you added it in the table parameters(rep_rel_sortorder) as shown in the picture?
I assume that being able to sort by parameters which are not in the table is something which has been added in later versions?
This option of sorting by parameter not in the table is available since pro-e 2001 I believe
Regards
K.Mahanta
Feb 14, 2012 7:02 AM UTC
Hi
I have got a solution for you
But you need to add an additional parameter in your part parameters(Not in your drawing table)
If this is acceptable to you
Then I can give you the solution
Regards
K.Mahanta
Feb 14, 2012 9:20 AM UTC
I would prefer not to have to add another part parameter, but if that is the only way then I'd like to see your solution.
Feb 14, 2012 9:26 AM UTC
Hi
you can sort your table by any part parameter or system parameter whether that is in the table column or not
You can check the ppt
You need one such parameter which will allow the system to consider parts first and hardwares later
Foe example
You can have a parameter XXX having value 1 for parts and 2 for hardwares
If you have any such parameters then you dont need to add another one
In the example you will find that I have sorted by type
But you can sort by any part or system parameter
Regards
K.Mahanta
