8-Gravel
October 5, 2010
Suppress "Select" dialog on function ProSelect
is it possible to suppress the "Select" dialog on the function ProSelect.
Similar to the "Sketch Tool".
With "ProSelectionEnvAlloc" and
ProSelectionEnvOption env_options[] = {PRO_SELECT_DONE_REQUIRED, 0};
no "OK" is required. So I don't need the dialog.
Is that possible?
Greetings Lars
We've created formats which have parameters pre-defined to fill in such
things as Life Cycle State and revision.
How do I prevent the user from entering text into that cell and
overriding the code we've inserted?
Is anyone familiar with any white papers or have best practices they
could/would share??
(The sledgehammer and dirty looks aren't working so well... lol)
Thanks!
Michelle McMasters CAD Admin/Process Integration Spec
Stanley Black & Decker, Inc.
Michelle.McMasters@bdhhi.com
<">mailto:Michelle.McMasters@bdhhi.com>
www.stanleyblackanddecker.com
MikePhillips
If you are currently using ModelCHECK I believe it has that capability. It
won't prevent the user from overriding the parameter values, but it can
search to see if the parameter call outs are in the title block and if not
(has been overwriting with text) prevent the user from checking in the
drawing until it is corrected.
Mike Phillips
FV_01
October 6, 2010
Hi all,
Michelle, 'ProDtlnotedataReadonlySet' comes to mind. It has to be combined with 'ProDwgtableIsFromFormat' and some 'ProNotify' events.
HIH.
Feliks.
In Reply to Michelle McMasters:
could/would share??
Thanks!
<mailto:Michelle.McMasters@bdhhi.com>
http://www.stanleyblackanddecker.com
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
________________________________
