Torque Motor vs Servo Motor
Hello Everyone,
In a mechanism (no resistive forces other loads), if I provide a servo motor to a rotating link, it behaves as expected where very minimal forces are generated in links and I believe servo motor just gives enough power/velocity to cause motion. So If i put a measure for reaction forces at various links, the force values are very less.
However, If i replace the servo with a finite value torque motor, reaction forces (equivalent in the order of a static case) are generated in the links even when there are no other resistive forces.
I would be much obliged if anyone could explain the above.
Thanks in advance
please ask the same question to PTC Support, too.
Hello @MartinHanak , yes, I have mailed the customer support.
Here is a sample mechanism. In a friction less model, the measures of connection reactions at A & B are different when we use a torque motor at center of wheel vs servo motor (angular velocity input). Rx A and Rx B for servo are negligible values as the servo does bare minimum to move the links. But the reactions when run with torque motor are much higher and cannot be ignored. So what is causing this resistance and generation of forces at connections?
kdirth
A servo motor will provide a constant angular speed (deg/sec) with a varying load.  In your example, the flywheel will turn at a constant angular velocity.
A torque motor will provide a constant torque (kg m).  In your example, the fly wheel will accelerate and decelerate based on the kinetic load of the system.
Hello @kdirth
Thanks for taking a look.  I totally agree with your explanation.
However, my original query was related to the "based on the kinetic load" part your response.
when there was no other load on the system (not even friction and no gravity), how come the torque motor still generates reaction forces at links?
