Tube and fin heat exchanger
I’m have a CFD project with an oil/water heat exchanger in a hydraulic tank. I would be studying how effective the cooler is at lowering the temperature of the oil over a given time so, it would be a transient analysis. The cooler has two cores with water looping through them in series. Each core has 182 copper tubes that are 0.4 mm thick and 170 aluminum fins that are 0.25 mm thick with a spacing of about 1.73 mm. I want to do cunjugate heat transfer across the solid geometry, but with so many components that are thin walled, the number of cells in the mesh woul be astronomical.
I'm looking for suggestions on a basic approach to this analysis.  Can the tubes and fins be compressed to mid-surfaces and run in CFA? That would require fewer cells in the solid domains. I see that there is something buried in the mesher about two fluid heat exchangers, but I haven't been able to find information on how to utilize that. Some direction there would be helpful too.
Hi @tmoser
Did you try the fluid study in Creo Simulation Live ?
Running Fluid Simulation Studies—Creo Simulation Live
I don't believe 2 phase fluids and conjugate heat transfer can be modeled correctly using csl
Community Moderator
Hi @tmoser,
Anurag
Hello, This kind of simulation is straightforward, we dont need to use heat exchanger, we could mesh whole thing together. Please contact your ptc support and this will be solved through technique support from Simerics.  thanks.
Oh i just notice your model has so many tubes, that may increase mesh count a lot. agreed, but just give it a try, we don't need to reduce the min mesh size a lot, try changing curvature control in the mesher to 5 degree etc to get better resolutions around the tubes, yes, just give it a try and see how big of the mesh you got. thanks
