UDA Results - Text Output
I have a UDA created that works fine, but I need to obtain the results from it in text form. The UDA measures the X, Y and Z locations of a field point from a coordinate system. The field point is constrained to a surface. I would like to have BMX output the results to a text file instead of a colored "heat map". Since it creates this color map, Creo has the data somewhere, but I can only obtain the max or min value for this study. Any suggestions or good hacks out there to find the text file?
TIA
