Use of computed measure in Mechanica WF4
- 1 reply
- 1484 views
- Translate All
HI, I have defined simulation measures to measure strain on two sides of a beam. Now I want to take the average on three tension side measures and subtract the corresponding (absolute)values from the compression side to run an optimization study on the beam using minimum difference between tension and compression strain as the optimization variable. Example: New measure = (T1+T2+T3)/3 - (C1+C2+C3)/3 I can find my simulation measures in the "Variables" window but I can´t seem to get the expression right. See attached picture. What is the correct syntax for writing expressions? Examples would be a great help! BR John
