Using fiber orientation of mold analysis in creo simulate
I'm new to the integrated mold analysis in Creo.
However, the tool with it's fiber orientation calculation possibilities appears to be promising for my topics. For the part design and the regarding analysis, I'd be very happy to use the calculated fiber orientation in Creo Simulate calculations. Is there a possibility to transfer the fiber orientation (and material properties) to Creo Simulate?
Best regards,
Daniel
thank you very much for the video, which is an additional help of course.
My main question is the transferability of the material properties due to that calculated fiber orientation into creo simulate to do strength/stiffness simulations of the molded part. Are there also tutorials?
Best regards and thank you very much!
Daniel
Late response, but did you find any way to export these data? All I am seeing is that there is no additional functionality of Creo mold results.
