Variable section sweeps
Fellow users,
I want to create a variable section sweep that uses the trajvar
function to vary the dia of a sketched circle along the trajectory. The
dia needs to be constant for about the first 1/3rd of the sweep, then
tamper down to a smaller diameter. What is the best way to do this?
Can I reference a datum graph?
Chris
Chris,
This is exactly how I would do it.
I have for your reference attached a part thats a great example of what
you are hoping to achieve.
Regards
Iain
REGISTER FOR AN EVENT NEAR YOU >>
Iain Lewis
Principal Application Specialist
T 07753 915635
PTC.com
