WF5 axis point
I remember being able to place an "axis point" in a sketch to cause a
datum axis to be created in an extrude. Is this still available in WF5?
And where is it? Can this be used with external sketches?
What I really want is an axis placed at the center of an extruded
ellipse... Is there another way to do this?
Thanks.
-Nate
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
Choose the point on the far left of the fly-out menu.
Jeff <><
rollinsn1-VisitorAuthor
Simple rename on PTC's part from "axis point" to "geometry point" and a
relocation from the "sketch" menu to the "create point" icon flyout.
Thanks all!
I've been using Pro/E for a very long time but this is a new one for me. THANKS !
I tried this technique and discovered that actually you need to select the center "point" icon on the flyout.
Bob
Thanks guys! I was thinking that there was some kind of mismatch between
modules of Pro/E. It's been a while since I have been working. IN FACT it
has been too long.
Well, at least I got to envision what it might be like to work on Pro/E
today.
The input here is rather good and I learned/remembered where that AXIS POINT
feature is.
Michael P. Locascio
