windows 10 purge function
I recently updated my system to windows 10 from windows 7. On windows 7 I had the purge function but now I don't have it on windows 10. Is there a way to get is back on windows 10?
Any help would be great!
Thank you,
Nick
purge command belongs to Creo/ProE, not to Windows.
Possible solution:
  • locate purge.bat in your Creo/ProE installation
    on my PC it is ... C:\PTC\Creo2_M070\Creo 2.0\Parametric\bin\purge.bat
  • modify system variable named PATH ... add path to bin directory
MH
Possible solution:
MH
npackard1-VisitorAuthor
awesome! That worked!
Thank you!
