Jan 20, 2011 6:47 PM UTC
5.3: Java client sdk sample, FOSI_PARAMETER not working
So, I was able to modify the sample script (e3script.bat, e3samples.jar, e3client.jar) to publish to the PE Server using the default stylesheet, but when I try and use our custom FOSI, the server returns the 500 error. I've tried to use all sorts of paths--to no avail
Thanks!
Alex
Here's my text file with the parameters that the e3script.bat file reads:
# Setup our policies (see the javadoc for more information).
setpolicy DELETE_PARTIAL_FILES_POLICY false
setpolicy LOG_THREAD_PREFIX_POLICY true
setpolicy LOG_TIME_DATE_PREFIX_POLICY true
e3 <u>http://Config8518VM0:8080/e3/servlet/e3</u>
basedir .
java com.arbortext.e3.E3AppTest
convert PDF_FORMAT
convert_set FOSI_PARAMETER Wide_D6_English.fos
convert_set INPUT_FORMAT_PARAMETER XML_FORMAT
convert_set OUTPUT_FORMAT_PARAMETER PDF_FORMAT
post <u>\\Plefilesvr01\techpubs\DropOff\AlexSato\temp\build-test\src\deployment_guide.xml</u> <u>\\Plefilesvr01\techpubs\DropOff\AlexSato\temp\build-test\output\deployment_guide.pdf</u>
    Jan 20, 2011 8:57 PM UTC
    no answers, but several questions that might drive you to a fix or help
    others help more.
    can you publish to your custom FOSI using Editor? or at least PE
    Interactive?
    if you open your FOSI with Editor or Architect are any problems reported?
    where is your custom FOSI? PE will look in
    custom/doctypes/yourdoctype/yourfosi.fos.
    is your doctype declaration right?
    satoa1-VisitorAuthor
    Jan 20, 2011 10:46 PM UTC
    Thanks, Paul. You inspired me to give it a go again.
    Actually, there was one path that I hadn't tried--I was trying to be too fancy. So, I tried the simplest path: c:\temp\wided6_english.fos. For the life of me, I can't figure out how to get the Windows blank space in the path to be read correctly (%20 didn't work).
    I also turned logging on, so I got a better error message telling me that it couldn't find the stylesheet. I also used the "stylesheet" param, instead of "fosi" (which I didn't see listed in the PE programmer's guide).
    --Alex
    In Reply to alex sato:
    Thanks!
    Alex
    basedir .
    convert PDF_FORMAT
