about the the Arbortext Programmer's Guide
Hello Experts!
I was wondering where I can find and consult the Arbortext Programmer's
Guide? Could you please give me a link or directions in order to access
this content, it would be pretty useful for me! 😃
Thanks a lot for your help and support.
Paulette Zorrilla
    18-Opal
    April 25, 2013
    Hi Paulette--
    It should appear in your copy of the Arbortext Help Center. In Arbortext, select Help->Help Center from the menus. In the Table of Contents, there will be a top-level section called Programming. Inside there is lots of good stuff, including the Programmer's Reference.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    pzorrilla1-VisitorAuthor
    OMG!! I found it 😃
    Thank you very much!
    Regards...
    Paulette Zorrilla
    There is some good information in there and I AM NOT a programmer, but use
    it routinely.
    Another way to see how things in Epic work is to look into the various files
    (other than the .exe files) and see how they get things done. This is
    especially true for ACL coding.
    Lynn
    And don't forget the adepters wiki at:
