accessing the replaced element from an embedded xui dialog on windowload
Hello Adepters,
I've created an embedded xui dialog box that's a simple dropdown menu, and its purpose is to let the user set an attribute value on the replaced element.
When the dialog box is loaded, I want the dropdown to display the current value of the attribute. But I can't figure out how to access the replaced element from inside the WindowLoad event handler. I can access it from the domactivate event by using:
Application.event.view.window.ownerNode
But Application.event.view is undefined when I try to do that from the WindowLoad event.
Any pointers? This seems like it should be easy to do.
-James
    Hi James,
    Try Application.event.target.ownerNode.
    In a WindowLoad handler, the Application.event.target is the window.
    Tung
    jsulak1-VisitorAuthor
    Thanks, Tung. That's exactly what I was looking for.
    -James
    18-Opal
    May 20, 2010
    Hi James--
    Yes, you have to use a different approach to get the window handles
    inside windowload as opposed to domactivate.
    To get the dialog document (the XUI document underlying the dialog) in
    windowload, I have to use this:
    dlgdoc = Application.event.target.dialogView.document
    So, it might work for you to do something along these lines:
    docnode = Application.event.target.dialogView.window.ownerNode
    HTH
    --Clay
