ACL and JAVA - Use of OID Value
Hello all,
Does anyone know how to obtain an Element or Node class object based on a valid OID value? I am working on a new AOM-based java application that calls an existing custom ACL function which returns the OID of an element which I then want to get in java.
I am pretty sure this must be possible. I have been searching through the AOM javadoc for a while today and have not found any kind of a "get element by OID" method. Any suggestions would be greatly appreciated.
Tom
    Tom,
    Look in the Programmer's Guide under the Acl Interface for DOMOID
    method. I believe in Java you can call it by either Acl.DOMOID(oid) or
    Acl.getDOMOID(oid).
    Brian Jensen
    bjensen@bluelid.com
    18-Opal
    January 17, 2013
    Hi Tom--
    You want Acl.DOMOID().
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
