May 16, 2014 2:43 PM UTC
ACL code not working
Using acl scripting in Arbortext Editor 6, How can an sgml file be opened and then save it as xml?
The doc_open method below returns a document identifier.
Providing this document identifier to the doc_save function saves an empty xml file.
Sample ACL Code:
#Open a sgml file
#0x200 - Open the document without loading a stylesheet.
$sgml_doc = doc_open("file.sgml", 0x200)
#save as xml
#0x0020 - Write the document as an XML document
doc_save($sgml_doc, 0x0020, "file.xml")
What should be done differently?
    May 16, 2014 2:53 PM UTC
    Did you not see my reply to your earlier thread?
    http://communities.ptc.com/message/243117#243117
    There is a different ACL command that converts SGML to XML.
    epichelp1-VisitorAuthor
    May 16, 2014 5:09 PM UTC
    We are executing ACL files via Arbortext Editor Command Line (ex: “source acl_file.acl”).
    A document identifier had to be provided to doc_kind() function to allow it to function for the document opened by doc_open().
    The following code sample produces an empty xml file. What are we missing?
    Sample Code:
    cd "c:/folder_to_sgml/"
    $sgml_doc = doc_open("sgmlfile.sgm", 0x200)
    message "sgml document identifier: $sgml_doc"
    $xmlName = "xmlfile.xml"
    if (doc_kind($sgml_doc) == "sgml") {
    message "document type is: sgml"
    save_as -xml "$xmlName"
    # Close SGML File
    close($sgml_doc)
    Jul 7, 2014 1:03 AM UTC
    Why did you switch from using doc_save to using save_as?
    Tim
    Aug 6, 2014 1:50 PM UTC
    Did you get this issue resolved?
    Was one of the posts helpful or did one answer your question?
